Throttle
PorscheLover
Hi I just bought a go kart from some one it had a 5 hp briggs and every time i try to drive it it takes at least 5 seconds before it starts to move im not sure if its the clutch(max torque) or my carb I think the guy replaces the stock pulsa jet carb with a vacu-jet cab. currently it doesnt even start at all the spark plug is fine but i think the carb isnt getting fuel or something. Please help. So my questions are how can i get better acceleration and how can i make it start?
Thanks
motor_head
expert garbage picker
sutherland IA
did you check for spark? just take out the plug and put it on the wire and hold it to the block by the rubber boot so you don't get shocked. it should be good and strong if it's a weak spark it won't spark under compression
PorscheLover
wow im stupid i just realized when i tried that i had a ground wire touching the frame and i took it off solved my problem
