Throttle return spring setup?
Slick68
OK, I'm installing a new Predator 212 engine on my Yerf-Dog kart. The engine doesn't really have a good throttle return spring setup for a pedal operated system. Does anyone have any advice on a system that they setup for throttle return springs? I can get a universal spring setup at the local auto parts store with different springs with varying tension strengths. If you have used this or something else, I'd appreciate the advice/comments.
I highly suggest the use of 2 springs. One to pull the pedal back, the other to actually throttle down the engine. You will have to experiment with different lengths and tensions. Remember to loosen the pivot bolt on the engine bracket so the mechanism is not stiff.
Here is mine, it does have factory return spring, but I need more "spring".
Slick68
Thanks for the tips. The pedal itself has it's own return spring, but it won't pull the throttle back where it should.
Slick68
Here's what I ended up doing. I had several springs and a chrome return spring bracket left over from an old car project. I had to drill the end to make the bolt hole the right size, then just bolted it to the recoil housing. Then I drilled a small hole into the throttle lever to attach the spring. I had to make several adjustments, but finally got it just right.
The throttle cable was getting in the way, so I used this old bracket(also from another project) and a longer bolt through the shock to zip-tie the cable up out of the way.
Poboy kartman
Senior Moments Member
White Settlement Texas
It looks very good, but what prevents the bracket from swivelling backward, pulled by the spring?
Looks like just the 90° footprint vs. the spring tension, good spot but wouldn't that be "forward? " being towards the front of the kart.
Oops-just looked again and it looks like there is a secondary anchor point near the throttle cable hold down.
Poboy kartman
