This looks sexy!! 335cc Rotax engine
South Kart3377
Kart designer
Va
I only spent a couple minutes google searching the Rotax 335 at these search links below:
http://www.google.com/images?q=335c...=UTF-8&source=og&sa=N&tab=wi&biw=1021&bih=649
http://www.google.com/search?q=335c...10&um=1&biw=1021&bih=649&ie=UTF-8&sa=N&tab=iw
I learned the OP's C/L find is most likely an 18hp. 1970 model, and had a 3/4" PTO:
http://www.vintagesnowmobile.com/cgi-bin/yabb2/YaBB.pl?num=1230105182
I would fully exspect that C/L engine to at-least be needing crank seals.
I feel that coupled with also needing a carb, air cleaner, chamber and clutch,
would take it from a low cost kart engine prospect to an exspencive prodject.
The pics below were all claimed to be 335 Rotax:
I cant see that the PTO Tappers, or has a keyway in any of them, so I have no idea what means
they used to lock the Driver to the PTO besides the outer retaining nut. That PTO must just have
a very slight taper.
______________________________
_______________________________
________________________________
I think the heavly tapered left side is flywheel, and PTO is on the right side of this crank pic below:
(edit: I held a pair of caliperes up to my computers screen and the end of the PTO did seem to slightly taper down...
:huh: You got it?
