thanks for everyones help
Nissinator1996
as you know ive been trying to put a generator engine with tapered shaft on a go kart well i had 3 other engines laying around so i solved all my problems by tearing down the perfectly good running generator engine and used all the part to rebuild one of my other engines took me about 2.5 hours to do but it was worth it when i got done i mounted it onto go kart and it started right up with 1 pull now i just need a clutch and a chain....anyone know a good chain driven clutch that uses setcrews and 1in shaft with keyway :D:D:D
anderkart
Surprise Arizona USA
If your output shaft doesn't have a threaded hole at the end, one option would be to use a lock collar like these to hold the clutch on: http://www.mfgsupply.com/gomini/gominisprockets/gominisprocketscollar.html
But the 14 and 17-tooth/1" bore, Noram 1600 clutches have set screws:
http://www.bmikarts.com/item/Noram-1600-Series-Clutch---41-1-400940-6003
http://www.out2win.com/catalog/noram.html#1600
I dont think the 10-tooth, 1600 model has set screws on the back side, but you could call/email and ask.
These cost less but definitely need a threaded hole at the end of your output shaft:
http://www.mfgsupply.com/gomini/gom...entcomet/gominiclutchcometscs400/206169a.html
http://www.mfgsupply.com/gomini/gom...entcomet/gominiclutchcometscs400/206170a.html
You really need to consider how many teeth the clutch has to get the kart correctly geared. We could help with that but we'd need to know some info, like:
How much horse power does your engine have?
How tall are your back tires?
How many teeth does your axle sprocket have?
Do you know if your axle sprocket is #35 or #40/41 pitch?
( if not, measure it and check this link: http://www.schultzengineering.us/chain.jpg
Will you be climbing hills/riding offroad, or just riding on hard flat ground?
