Tecumseh torque converter belt size?
Sirbuildsalot
I bought a Murray with a 5.5hp Tecumseh and torque converter. The belt is missing though. Will any 30 series belt work?
Sirbuildsalot
You need to measure the center to center distance between driven and driver and then look on the chart for the belt that you need. The pulley diameter also matters
Comet identification, installation and belts. Sprocket and spring changes
http://www.gokartsupply.com/identify.htm
http://www.gokartsupply.com/tcbelts.htm
Thanks, I actually found it on a website called partsandservice.com. A very handy site as it will provide and blown up diagram and parts list for just about anything with a model number. In case anyone else has this problem, the belt number is 37X98 or 203597
