Tecumseh specs
Agent_Orange
Waterloo NY
where can i find specs on a 4 HP Tecumseh from a craftsman 4/20 snow blower 536.885400 8264. the internet is not revealling any sources and i thought i looked high n low. I was looking to get compression ratios, carb specs, displacement...
For some of those specs, you're going to have to find a factory service (rebuild) manual. Tec ones can be tough to find, and/or cost you. I will look thru my collection. Do me a favour- post a pic or two of the engine.
EDIT- Is that the number off the machine, or off the engine? I need the engine numbers...
Manual probably will NOT reveal compression ratio.
Agent_Orange
Waterloo NY
engine #'s
Snowthrower manual (536.885410):
http://www.managemylife.com/mmh/lis_pdf/OWNM/L0810227.pdf
(also valid for 536.885400 according to searspartsdirect)
Engine
PART NUMBER: 300848 (unavailable, no further info)
the engine on the 885410 would be craftsman 143.804062,
which is a Tecumseh HS40-55586M
(covered in this manual)
But if Chris says, it's an H40, it'll be most likely an H40
So please check your engine for a part number ;)
That's close enough- The HS40 is a variant of the h40, with precious little difference. It's a 4hp L-head. But thanks Alex, for putting up that link- saves me from having to email mine to the OP!
