tecumseh recoil spring.
Blazkowiez
Kart Aficionado
Houston, Texas
You must have a hollow structure supporting the recoil when you punch the pin out so the pin can drop into the hollow (socket in your manual) item and not damage it. Once you've removed the pin the starter should be free from the housing. I will warn you how expensive the springs are expensive as is the pulley that the spring fits into.
Blazkowiez
Kart Aficionado
Houston, Texas
Does that make much sense why they charge that much for a spring versus 4-7 dollars for other retailers? Not to sound crazy, but you're welcome, unless my explanation made no sense to you.
