Xtreme Yard Karts
Many moons ago, I raced go karts and I ran Tecumseh engines. I started out running modded small block HS50's and later moved on to big H50's. When the Animals came out, Tecumseh had a Motorsports version of the OHV 195cc engine that had a billet rod, high compression head, stainless valves with HD springs and aluminum retainers with automotive style keepers, a hotter cam, hot coil, a Tillotson carb, a ball bearing crank cover. They were MUCH stronger than the Animal engines.
Despite the opinion a lot of people have of the Tecumseh OHV engines, they can be made to run very good, and make a lot of power. These engines in stock form had a horrible fixed jet carb, and the Regular versions had a plastic cam that could not take heavier springs. I few years back I bought a bunch of NOS Tecumseh Motorsports parts and until I haven't done anything with it. It's spring time, and I've got my kid's karts going, so I've decided to build a couple of these for myself. I'm starting with a fairly mild build, and I'm going to build a high RPM, race version later.
Enough blabbering, here's the details.
Standard bore OHH60 6HP Powersports 195cc (11.88 cu in)
Stock piston with new rings
Deburred, polished stock rod with chamfered oil hole
Stock crank
Dyno 245 cam - 245" lift, 216 duration @ .050, 110 lobe center (this is a good all around cam. Makes good torque and pulls to around 6500 RPM)
Ported OHH50 (5HP) head, stainless Motorsports valves and retainers, Dyno 18# springs
Custom made intake with 18mm Mikuni clone round slide carb
Tecumseh Motorsports hot coil
Robertson Torque Tubes 4 stage header .906" primary pipe
---------- Post added at 11:17 PM ---------- Previous post was at 11:02 PM ----------
I've had great success with deburring and polishing the stock rods. I've never hurt one up to 6000RPM. I grind all the casting flash off, and round all sharp edges. I open up the opening of both ends of the oil hole. I ran these on the track like this and they worked very good for me. On higher HP, Higher RPM, I'd go billet. The billet rod is a good insurance policy anyway, but for what I'm going to be doing with this engine, I know the prepped stock rod will be fine for me.
The stock piston and crank are fine in these engines. They have a big 2.795" piston with a short 1.938" stroke. The internals in these engines are lighter than any other engine this size I know of, and they love to rev. This is pic of the piston vs a Briggs 5 HP piston.
---------- Post added at 11:29 PM ---------- Previous post was at 11:17 PM ----------
The OHH50 (5HP) engines have a 19cc combustion chamber and the 5.5 - 6.5 OHH55 - OHH65 engines have larger 23cc chamber. I this one, I milled the head .040", ported it, and used stainless Motorsports valves and retainers, and Dyno 18# springs for Briggs Intek/Animal, sbc polished the combustion chamber.
The runners are actually a pretty good size in these heads. The main porting work was done opening the bowl to he ID of the valve seat, opening up the transition from the runner to the bowl, and tapering the floor and rounding the short side radius. There's no need to hof them out on a build like this. These engines have small valves compared to something like the clones, etc., but the heads flow plenty with port work on a build like this.
---------- Post added at 11:31 PM ---------- Previous post was at 11:29 PM ----------
The cam and the Motorsports hot coil.
Stock crank
