Tecumseh Ohv 6.5hp
2SlickNick
American Minibikes @ FB
Mesa, AZ.
Hey Everyone,
I have a tec 6.5 that had a bad carb and fuel line.
I replaced with new carb, fuel hose, and air filter.
The engine started right up... But then started billowing white smoke.
The plug is pretty fouled and a little wet.
The old carb had oil residue in it.
Oil is in need of changing and just a tad high above normal level.
I read somewhere that these engines commonly get clogged breathers. My breather to come from valve cover to carb.
Does anyone have any experience with these engines. Do I have to replace the entire valve cover or is there a reed in there that I can replace?
The piston does have a lot of carbon buildup on it but I do not want to go inside the engine at this time.
chancer
ɔ ɥ ɐ u ɔ ǝ ɹ
COMFORT, TEXAS
Dont know specifically about the tec.
But I hear a little water in the carb will knock the carbon off the piston.
But get better advice and how to before trying.
Atlanta, GA
Did the white smoke smell like oil burning? I always think "white smoke: Head gasket" but that's in autos of course.
Grape Ape
Virginia
Check to see if you have oil on top of the piston, excessive oil that is. If so then I say rings, if no then I say too much oil in crankcase. Not an expert just past history with small engines.
Could be bad rings. If you can, run a can of SeaFoam in the gas tank, that helps get rid of carbon deposits.
Toycrusher
Deep Deep South Texas
Bluish white smoke is oil. You definitely want to start with correcting the crank case oil level. Next, just try blowing through the breather to see if it's plugged. If you do in fact have carbon buildup and stuck rings, the best product is called ring-free and it's from Yamaha. I've had lots of personal experience with it and it's very impressive. You are required to change your engine oil after running a tank of ring-free because of all the contaminants it breaks loose.
