Tecumseh OHH55 not starting after modifications
soggycrashed
Honolulu
I don't think so. The enduro cam and plastic cam don't bind. Im going to swap the plastic cam back since it has more lift... Trying to figure out why it won't rev past 2000rpm.
soggycrashed
Honolulu
Found the issue with the Dyno Cams 255... exhaust lobe was hitting the crank. Ground the lobe slightly, sanded and polished and it turns over without binding now.
Flywheel key was sheared, which explains why it wouldn't rev properly. Also need a new head gasket now.
soggycrashed
Honolulu
Got it working guys! Cam is terrible for low end power but once the kart passes about 10mph it picks up real fast. Goes about 40mph before valve float.
Took is for a ride, then proceeded to smash at full speed into a curb and break two tires. Going to need to be fixed XD
Also, a bit if smoke comes out the breather at full speed so I have to check up on that.
