Tecumseh OHH50 problems
fatnfurious
Okay I think the problems are mostly fixed, the engine has trouble starting but once it runs it is good. The problem with the engine dying going up hill was gas not going through the fuel line because it uses a gravity system so putting more gas in the tank should fix it
Second that. Start with the carburetor. As much as I usually get along with Tecumsehs (some folks hate 'em for varying reasons) the carbs can be a bit temperamental, sensitive to junk in them.
Metal_Rott
Laredo, TX
The engine runs great occasionally but now its stopped running so good. The engine has trouble idling and the clutch is always engaged a little so it wants to take off. Under load when I floor it sometimes the engine will almost die and won't go for a few seconds before getting gas back which is what this feels like. I've had a few mechanics look at this engine and had the clutch and everything aligned, but it's still causing problems and I can't figure out what is wrong. I also recently changed the spark plug and added oil to the engine. Does anyone have advice?
edit: I've cleaned the carb a few times it doesn't help and the main jet is clear
Yea it sounds like dirty Idle and Intermediate/Air Bleed Ports. Did you use a Can of Carburetor cleaner when you cleaned the carb out? You want to use the straw with the cleaner and spray every little hole you see. Be very liberal and take apart as much of the carb you know how. Then use the straw to reach in the small holes and give it all a good deep spray.
The Ignition Coil can get rusty. Have you checked or cleaned the rust of the Flywheel and Ignition Coil ? If you have the governor still in place, make sure all the springs are connected properly.
Also Try adding an Octane Booster to your fuel, that could help dilute the debris in the carburetor and clean it while holding the throttle open for a bit.
fatnfurious
I cleaned the carb but only used half the can to do it and I only know how to take off the main jet and bowl, nothing else. I think the governor linkage is correctly put on and I haven't cleaned rust or checked the fuel lines since I don't know how to.
Metal_Rott
Laredo, TX
Is it possible to get some pictures posted?
There are several other little holes that need to be cleaned. Take it apart as much as possible and poke out all the little holes with some thin wire. I usually pull a strand out of my wire wheel. You can also use the wire out of bread twist ties. That is also thin. People have also used thin guitar wire.
Have a look at these links for Tecumseh carb maintenance
Tecumseh carb cleanup, servicing and troubleshooting
http://www.kichline.com/chuck/fixit/mowers/tcarb/tcarb.html
http://www.smallenginesuppliers.com...cumseh_L-Head_Engines_Service_Information.pdf
http://www.smallenginesuppliers.com...cumseh/Tecumseh-basic-service-information.pdf
