Tecumseh HM100 10hp Linkages
GregJr
MA
Hi all, New guy here. Great info. I just bought a Carter Bros kart that was missing some of the linkages between the carb and governor and throttle. The po took the carb off to clean it and lost some of the pieces. He got mad, so now I have it for a great deal. Would anybody have some pics or some advice as to what I need? I looked online for a blow up, but I cannot find the exact same config. I have attached some pics for reference. Thanks in advance, Greg
GregJr
MA
Hm100
Thank you, I had seen that before, It is almost the same setup as mine, however, my carb comes out straight rather than to the right. So in order for the gov linkage to move the butterfly on the carb, it would have to push/pull from a different angle.
karl
North east Ohio
This might help , not my motor. Found on web.
edit- not your motor, exhaust is not on right side, duh, but should be the right idea
