tecumseh exhaust flange?
carter
I want to upgrade the exhaust on my tecumseh to a straight pipe or something of comparable flow. Does anyone know where I can get an exhaust flange for an HM100, or possible even a pre-made pip/exhaust? also where I might get a kit/piece to convert from my stock exhaust to a high-flow exhaust? Thanks
carter
it looks like it may, I can't exactly see the mounting plate though. but it is almost exactly what I want.
I was really confused at the oldminibikes thing, I was thinking you were telling me to use the EBAY on their sight or something.
carter
The problem is that there are no specs, no alternate shots, or really anything to go off of.
carter
It does however say it is meant to fit engines that start with H, and he resemblance to the flange on my stock exhaust is uncanny.
anderkart
Surprise Arizona USA
http://ombwarehouse.com/Briggs-Laser-Cut-Flange.html This appears to be almost exactly what I'm looking for, thanks anyway though.
That flange ^^^ is most-likely made for 5 or 6.5-hp engines, and too small for a 10-hp Tecumseh.
But Robertson sells 3-stage race headers to fit your 10-hp Tecumseh. (they'd also sell you just the flange If you asked) Their header models made to fit the Tecumseh Star/10hp is the one you'd need.
You'll find them at this link:--> http://www.robertsonstorquetubes.com/tecumseh.htm#tecumsehst95
carter
I've already got the flange, along with a carb kit on the way. Thanks for the link, if making my own with his flange doesn't work out I'll certainly get one from the site you recommended.
On an offnote do you know where I can get something to convert to a high-flow air filter?
