Blakey
Time Traveler
Hey everybody its everyones favorite carburetor! Whoo hoo! Actually I don't mind them on a stock motor, its just not as sweet as an adjustable version. People really get frustrated with these buggers simply because they are prone to plugging up the little orifices from dirt and gum. I highly recommend using a line fuel filter and to remove all traces of fuel from these carbs if you wont be using it regularly. (storage)
So here is the beloved "Punching Bag" as I call it. Really poor cold start ups with out a choke, but lets face it, they tried to make it dummy proof for the dummy users out there who have no idea how to use a choke.
Anyways... you will need to now go down to the market and buy the important carb cleaning tools - A loaf of bread, some peanut butter and jelly. (burp)
You see the specially tool is a bag tie with the paper removed. Don't cut it down because it will flatten the end and wont fit the holes properly just remove the wrap and use.
Now lets find the feed hole in the side of the main jet well. In the picture I circled the plug where they drill the hole into the well. Don't remove the plug, we want to work the other side.
Here in this pic I bent the tool and placed it in the idle/low speed feed hole.
Once you have punched through the gunk in that hole then move up to the venturi and use your tool to clear the idle and transition holes.
Now remove the idle/low speed jet and spray carb cleaner into its hole and you should see fuel spray out of the 4 holes you just cleaned with the tool.
Now clean the idle/low speed jet with the tool and spray cleaner through it too.
Now comes the most important part...the idle/low speed supply hole drilled into the side of the main jet. This is so easily overlooked. The main jet seals against a rubber seal at the base of the emulsion tube; this tiny hole is the only source for the idle/low circuit. If this tiny little hole is plugged or semi-blocked, you won't idle or you will have poor off idle performance.
See the hole?
How about now?
Clean it up and spray it with cleaner.
Okay. Now set the float..
Stop eating so many peanut butter and jelly sandwiches, put it all back together, and hit the road.
Oh and one more thing, clean your computer. Sheesh! Oh wait, thats mine =(
Prost!
See the hole?
How about now?
Prost!
