Tecumseh 250cc governor/throttle problem
carter
Tecumseh 250cc governor/throttle problem [matter resolved]
I have a tecumseh 250cc engine and the governer/throttle isn't working properly, when I push the pedal the part that is mounted on the engine turns but the part that is connected to the butterfly on the carb isn't turning and ergo, the butterfly is stuck closed,I took off the spring that resets the throttle due to the fact that it rusted so I got a replacement but when I went to mount it I couldn't findd place to so I had someone hold the spring so it would have some tension on it while I pushed on the pedal so I could find a place toputit but the part connected to the butterfly won't turn
[EDIT]found a picture that showed of where the spring was supposed to go and it fixed my problem, sorry for taking space on your forum with this
http://www.google.com/imgres?q=cart...6&tbnw=224&start=0&ndsp=15&ved=1t:429,r:0,s:0
here is the picture from anyone else with this problem.
