TC for 1 1/8" shaft???
oxyjansen
Massachusetts
So, I traded a bike for an old Kango kart, and an 18hp Kohler twin with a 1 1/8" output shaft. Now, as I look at TC set ups my best options appears to be the Comet 44 Magnum 209706A for the 1 1/8" shaft. Best price so far is $160 for the drive side only. Is there anywhere I can get one cheaper?
Is there a TC that can be bored from 1" to 1 1/8" to save me some $$?
I don't really want a $1000 kart on my hands. I did see someone do a sprocket to a jack shaft, but by the time I get bearings, and shafts I'll be into it at least the same amount if not more, and the engine bay will already be tight with the twin.
What about a 4 bolt plate mounted to the engine that could support a small shaft with a sprocket and TC with a short chain to keep things very compact?
oxyjansen
Massachusetts
Kango pics
Here's some pics of the kart. There's a fair amount of space because it was built to hold a big battery but the twin has a decent footprint and I'd rather keep things as clean as possibly
well...
that is a dead axle kart you have there.. installing a 18hp engine with a cent clutch will nearly make it impossible to take off already (loosing traction since all power is going into one wheel)
installing a TC will double that torque at least and it'll get worse ...
So, I'm afraid, that's the wrong chassis for that.
You can convert it to a live axle to spread the load of course, but frankly, that'll just adds $$ to spend.
Maybe you should sell that one and just buy a live axle chassis to use as a base.
oxyjansen
Massachusetts
well...
I definitely realize its an axle conversion, which isn't an issue for me. Its actually made well, and with an extension to fit an adult properly, and some extra support in the rear it may be an interesting project. But, as you mentioned, unloading it for a different frame isn't a bad idea either. I was just thinking of working with what I have. I like the "loop tail" as well, as it reminds me of the old school BMX bikes from the 80's.
In reality, I really like the Dingo. I recently missed one that was almost completely rebuilt, and the guy just gave up on the project. There are tons of them around as well. I'm in a position where planning, and not spending a ton of $$ is my only option at the moment. I'm hoping the eBay gods will be kind to me this Xmas! Or, that I can continue to trade off bicycles for parts, etc. I've been building custom bikes for a while now, but it hasn't been very prosperous.
---------- Post added at 01:19 PM ---------- Previous post was at 01:18 PM ----------
I think this is your best bet if there's room for it.
Have you seen such a set up before? I was just curious to see pics of other designs. Always helps in the design process.
oxyjansen
Massachusetts
http://www.mfgsupply.com/gomini/gom...chtorq40/gominiclutchtorq44drive/209706a.html
you shouldnt get anything bored, especially when putting it on a 18 hp engine. this one can be used with the 40 series driven unit.
there is always the comet 780, but it will cost you 500+ for that setup.
So, is there a big difference between the 40 and 44 series? From what I've read the 44 series driver is pretty heavy duty, so I'm wondering if for the sake of strength is it worth spending extra for the 44 driven unit? We are talking about 18hp after all! LOL
Oh, and can you give me an idea about gearing from the converter to the axle? I'm not sure what I can fit on the front of the cart without mods, but I'd like to put something like 20" tires on this thing since I'll have the power to move them. I can widen the front if necessary, though I'm sort of inclined to leave it alone. I'm thinking may tires off a lawn tractor.
What is the safest length of axle protrusion past the bearings to the wheel without worrying about bending the axle? Assuming a 1" axle is used.
KartFab
Dallas, TX
With that engine, you can safely gear for up to 40 mph.
I'm not sure of exact ratio, but a 10t jackshaft and 60t axle sprocket should be ok, solid steel sprocket though. Chain might stretch prematurely too.
oxyjansen
Massachusetts
Ok I'll make a note of that. I'll definitely check back in once I get the actual wheels I intend to use.
So will it matter if I use a 40 or 44 driven with the 45 driver?
I was on your site and I like the steering design. That will help a lot in the conversion. Do you have a preference for a particular rod end?
KartFab
Dallas, TX
Just look up comet 40 series manual (bmi karts has it for viewing). You can find part numbers for the driven units to be sure.
Tie Rod ends are tie rod ends, I have no preference.
oxyjansen
Massachusetts
I'll do that. After doing a little measuring and contemplating I've decided to sell this kart frame and do all the work on a lawn tractor. Unless of course I come across a cheap kart frame in the process. We put the kart together today with wheels and roll cage and it ends up being deceptively small. My friend mentioned 18hp and pretzel in the same sentence which really got me thinking! Lol
I've taken notes and will be back with a better project soon. Thank you for the assistance!
