TAV2 and engine RPM questions
vpd66
Wisconsin
I have a TAVs 30 series torque converter on my mini bike. I have a 212 non-hemi engine on it with the governor still hooked up. Right now with the speed limiting screw backed out I see 4000 rpm when I hold it wide open. The rpms come down to 3900 when I really get it strung out (I assume this is the overdrive ratio that makes the rpm drop some). My question is: if I remove the governor will the TAV2 limit the engine speed? I know 2 stroke snowmobiles and atvs use a torque convertor setup and have no governor. The torque convertor on them loads the engine and limits them to a certain rpm. I don't what to remove my governor and would like to rev my engine to around 4500-4800 rpm. This way I don't have to buy a billet flywheel,connnecting rod, and stiffer valve springs.
950speed
Texas
Should be able to adjust the govoner springs on the arm, other than that and backing out the screw that’s as much as you can do without removing the govoner.
I personally have never moved the springs to a different hole, just removed it and never rev it up past 4500 rpm. I have a digital tach and valve float also limits revs before any damage can be done
Maintenance will have to preformed more often
vpd66
Wisconsin
I'm going to try the different holes. The problem is that it is under the fuel tank and not easy to get too. I have a digital tach and its no problem for me to keep at a decent rpm, its just the few times I let some else ride it that I'm worried about it being over reved. I can't see putting that kind of money (flywheel $100, connecting rod $70, and valve springs $20-$30 at a minimum) into the engine. Me and a buddy built a Clone engine up about 7 years ago and it got out of hand in a hurry. When we were done we had almost $1200 in the engine. The first time we took it out it broke the #35 chain on the kart on about the third hole shot.
950speed
Texas
Yes try different holes. T makes it easier if you unbolt the tank and keep hose connected and just use needle nose pliers to get in there.
vpd66
Wisconsin
I've seen a YouTube video where someone claimed to get 5000 rpm by moving the spring on the governor lever. When I get some free time I'll have to play with it.
