Switching Crankshafts
currier35
Rhode Island, U.S.A.
So... I have a tecumseh ohh60. I have the chance to get a Predator 11hp. On my kart I have a comet torq converter with a 3/4" bore on the driver part. Since I really don't want to buy another TC, I was wondering if I could just switch the 3/4" crankshaft on the tecumseh out with the 1" crankshaft on the predator. Is it possible?
porsche930dude
Upstate, NY
no way man every crank is different. you could have the crank machined down to 3/4" . i dont know the cost youd have to call around i know its a simple job so it shouldnt cost much especially if you remove it yourself.
currier35
I kinda thought that they would be different.
Good idea! I'll have to look into that.
Also, I'm going to look into if I can buy a 3/4" shaft for the predator.
I just looked into that, and that still runs me about $120 with shipping.
Maybe I can bore a 1" hole in the TC Driver..
Nope not enough material,
Oh, and the comet TC I think you are referring to, is only rated for 8HP, I think at least you will have to buy a new belt every now and then to keep it running on a 11HP engine ;)
maybe you should get just a knockoff driver instead of a original Comet
like this:
http://www.bmikarts.com/30-Series-Driver-Unit-with-1-Bore_p_2508.html
(50 bucks)
With a 11HP engine the cost of buying new belts every couple of weeks is going to break the bank. You could potentially be spending $25 on a belt every 2-3 weeks.
A Comet 40 series (or chines equivalent) is what is called for with 11HP. You can use the 30 series, but you will be paying the big bucks at the end of the day for belts. Why not just spend that money and get a TC that is appropriate
currier35
I found a comet 40 on the trade/sell section on here. Hopefully I can get that!
