Sunl 110 burning up clutches
jeburg
Hopewell Junction, NY
Hello,
My son's Sunl 110 keeps burning up the clutch. I have put in three and the don't last at all. Does anyone know why this keeps happening and what I can do to correct it?
the sunl 110 has a manual clutch right?
if so you might not have set it up correctly so it doesn't fully engage.
(happens if you try to move the lever closer to the handle for smaller hands... that always ruins the clutch if you're not adjusting both end of the control cable ;))
jeburg
Not a manual clutch
This gokart uses a centrifugal clutch.
firemanjim
Just kartin' around....
Houston Texas
If you did not soak the clutches in oil for 24 hours (ish) then they are going to burn up REALLY quick....... :thumbsup:
jeburg
It is pretty much the same motor but on a gokart. The amount of weight is two kids weighing about 80 pounds each plus the weight of the go kart. Gokart weights about 350 pounds on it own.
The gokart is a SLGK-110, 6.26 HP motor.
if it's the same as the sunl 80 on my son's atv it's an "auto" which is just a centrifugal clutch how much weight are you trying to push with it?
jeburg
The rear tire size on the gokart is 16 x 8.00 - 7.
The bottom (axle) sprocket has 38 teeth and the top (motor) sprocket has 14 teeth.
There is 4 3/4 inches of space between the bottom of the axle sprocket and the ground. I could increase the size of this sprocket by a pretty significant amount of teeth.
Are there kits to convert a centrifugal clutch to a torque converter?
Well there is your problem.....You have a 2.7:1 gear ratio. I am not surprised your clutch is burning up. You are going to have to get at least a 12T clutch and a 72 tooth axle sprocket. This will give you 6:1
firemanjim
Houston Texas
I have to dis- agree with you landuse..... It has a 110 cc atv/motorcycle engine with auto trans. It was geared like that from the manufacturer, I THINK...... BUT I could be wrong....when you replace those clutch plates, they MUST be soaked in oil before being installed......
I have to discuss agree with you landuse..... It has a 110 cc atv/motorcycle engine with auto trans. It was geared like that from the manufacturer, I THINK...... BUT I could be wrong....when you replace those clutch plates, they MUST be soaked in oil before being installed......
Aaah, so it is not an indusrial engine.
Then I apologise....
jeburg
Hello - Thanks for the explanation. It is an automatic transmission but only has one gear plus a reverse. What is a 12T clutch? And where can I buy one and a 72 tooth axle sprocket?
If you have an automatic trans, then I would suggest just getting the 72T sprocket. They can be bought at various kart stores as well as some hardware stores
And......:useless:
jeburg
I am not sure if that needs to be done or not, but it sounds like a good idea. I will try it the next time I replace the clutch. Thanks for the advice.
