Subaru EX27 low oil sensor disconnect
metalthrashinman
Hope, NJ
Hello all. Thanks in advance for your replies. I have removed the stock EX17 engine from my kart and installed the EX27 motor from Subaru Robin. MAJOR modification because of the larger footprint and the 1" shaft, but an incredible difference indeed! Problem now is stalling when turning, on hills, and large bumps. Anyway, after searching on this awesome forum; I have found that it HAS to be the low oil sensor shutting the motor down. She starts RIGHT back up after stalling -- on the first pull. Question is: Has anyone disconnected this sensor from this motor and if so, how did you do it? The manual that comes with the motor leaves much to be desired...
metalthrashinman
Hope, NJ
Thanks for the reply. I found the sollution myself. There is an orange wire connecting to the engine on/off switch. It had a disconnect plug on it and I simply unplugged the wire. Oil sensor disconnected and no more stalling! Project completed. Estimated speed of kart is 55-60mph. Very impressive kart now. My son is very happy and so am I!!!!!!!!
