I have the 16 ton, make sure the bead line is to the bottom, mine is always to the bottom, I have made 90's without sand on 1/2" and 3/4" by moving the pipe 2-3 inches, the radius is bigger, but no pinching... also, use the 2d roller pin holes out on 1/2" pipe, 3rd on 3/4 much much cleaner and no crimpy... but the bead for the weld is crucial not to be out, to the sides usually works out, but that weld isn't the same metal as the pipe, 30,000 psi pipe with 70,000 psi weld = weld won't bend as fast period. if its on the bottom, it doesn't have to stretch, just hang out and enjoy the ride.
it can't be beat for the price, but its not a mandrel bender, it will always squish the pipe somehow if you bending past 60-75 degrees in a single bend, sand might push that out, but 90's will still be rough... I would plan on 3x30 degrees within 4-6 inches, so that means bend 30, move 2-3 inchs, bend 30, move 2-3 inch, repeat one more time and your at 90 with clean bends and not bad looking, 2x45's kind looked odd and choppy, but 3x30 I had good luck with.
I've spent $400 on steel probably for my mini buggy, keep your mistakes, you can cut them in half later for something. but you won't get it right every time no matter what until you've dropped some dimes on practice. if the HF bender was indexed for angles, It'd be easier, but it was designed for sched 40 rigid conduit which by default no one cares as long as the wire fits a kink does not bother the wires once they are run. the fact that water pipe fits is only a bonus to us since its so cheap! but cheap steel and cheap benders = crappy bends sometimes. keep in mind my ENTIRE buggy is bent in an HF bender and anything round is pipe.
you must use schedule 40 pipe, sold as handrail, black pipe, galvanized pipe (try not to use galv, bad toxic welding fumes)
3/4" schedule 40 is like just over 7/8"ID, and 1.25+/- od, 1/2" is just over 5/8 ID. 1.125+/- OD if you are trying to use thin wall conduit, you can't, period...
you can try using one of the really big dies for smaller pipe, it does help due to the large radius, but it more flattens the steel than kink folds since theres no side support.. a different look, depending on part you are making, it could be OK.
thats my 2 years. hope it helps.
