Streetlegal 420 predator
vegasboy
Las vegas
What's up guys, just wanted to show you my latest Predator project. Just ordered a few more things for it little bit of fabrication left. She will have a 420, with a 24 inch tire 10 tooth clutch and a 70 tooth rear sprocket. She should do 55 plus, last time I learned my lesson I'm not going to mod the motor. And I got a way better clutch this time with needle bearings.
Quinc
Sub'd! Should be an interesting build! Also how are you going to get it street legal?
vegasboy
Las vegas
That's simple, in Nevada you just start with a 17 digit VIN number on a fork it's already been registered and the bike will be registered as that instead of a custom. I've made a couple of these before that were street legal with plates
vegasboy
Las vegas
Here is an old version that I built a few years ago I used to drive all the time back and forth to work, and even took it from Las Vegas to Laughlin
vegasboy
Las vegas
Small update on build. I refabricated the turn signal and license plate mounts with a new bigger better tail light. I used old turn signals to mock it up and we'll replace them with new Amber units. I also built the brake Rod and pedal how to hook up the rear brake.
Thats some nifty work you did on the brake linkages :thumbsup:
vegasboy
Las vegas
I've always been annoyed when trying to drag an object in a forward motion when it has to be attached to something that has a rotating Arc. I had to really think about how to get that rod to go forward as straight as possible and have some travel to activate the rear brake.
