Streaker Fun-Wheels Parts advice
BarefootStreaker
Charleston, SC
We recently were given a Streaker Fun-wheels and have it running, but need to know what we need for the shaft bearing. We don't have the original bearing so not sure what to purchase and also what else we may be missing. The key was sheared but have a new one and believe we now have all the shaft parts needed. We did remove pieces of what appeared to be a metal ring within the raceway.
Can anyone direct us to an exploded view, or direct us to the correct bearing or other needed parts?
Thanks for your help and below are a few pics.
KartFab
Dallas, TX
Ok i dont have enough information from the pictures, but I can give it a stab.
Top pic is of the metal plate bolted to the engine? There used to be a comet 30 series torque converter attached to that. Bearings on the jackshaft should be high speed 5/8" ID 1 3/8" OD sealed. There should be two of them that go in there, one on each side.
Bottom pic Axle is 1", you will need 1" go kart bearings. They should have a flangette that holds them in place (you can just use the old ones). You might see a little set screw on each bearing that will need to be backed out first, then spray some rust buster in there (liquid penetrant) to help with removal.
Front bearings Also are 5/8" id 1 3/8" od, w/snap ring. Dont overtighten the bolt that holds the bearing on or the bearings will not work like they should/wear out. You may have a hub (requires 2 bearings) or the rim itself will accept bearings (still same bearings)
Hope that helps! You are looking at $20-$35 worth of bearings.
BarefootStreaker
Charleston, SC
Yes, you are correct a Comet 30 converter is what we have. And we're looking for the jackshaft bearings so your information will help. Is there anything that should go in the raceway as we removed what appeared to be a metal ring of some sort?
Thanks for your help.
KartFab
Dallas, TX
the metal ring was probably what was left of the old bearing........ your guess is as good as anyone's given that we have no pictures of it.
jack-shaft needs (besides the plate that you already have)
the 5/8" keyed shaft
3/16" ke
sprocket (probably 9-10 tooth)
nuts to go on each side of the jackshaft (or lock collars)
2 bearings, one for each side of the jackshaft.
Sometimes karts have a spacer that has an inner diameter the same as the outer diameter of the shaft to keep you from over tightening the nuts on the bearings (eg 5/8" pipe between the two jacksaft bearings, or a 5/8"pipe between bearings on the front wheels ). This is not a required thing to have, but is very useful.
So this is what we are looking for for the Jackshaft?
http://www.mfgsupply.com/az8205.html
yep
