Stick weld on a frame?
number9
KY
Anyone on here ever weld on a frame with a stick? I've got a Lincoln AC/DC 225 welder and don't really want / need to buy a mig welder just for using on karts.
I'm planning on adding a mechanical disc brake mount and some other weldments to the Manco American Express frames, not actually welding up a new frame.
Any tips on rods / amp settings to use from those that have would be great.
chancer
ɔ ɥ ɐ u ɔ ǝ ɹ
COMFORT, TEXAS
It should work fine. Just a little practice, and the right settings on your welder and the right rods.
Search the FAQ section and helpful links thread. I remember ther is some great info there.
tazmannusa
Yettem, California
I use to build buggies and even roll cages in a baja bug with stick, didn't have a mig and I was outside. 3/32" or 1/8" 6011 rods, start out around 75 amps DC electrode + and practice . adjust amps up or down from there, try both sizes of rods to see what works best for you
number9
KY
Thanks guys. I've got some 3/32" 6011 already. Just wanted to ask for some confirmation. I'll practice on some scrap to dial the settings in of course, don't want to blow through the frame for sure.
machinist@large
West Michigan, 49331
I have welded everything of mine with stick. I use 6013
Paul, you and I dug into that when you were having issues on one of your builds. That time you were fighting it out with the correct dia. rod. And while I first learned how to stick weld with 6013, it's nickname in industry is "Liar's Rod" because even if you do everything correctly, there is zero garuntee that you actually have a good weld.
While I personally have very little use for 6013, I personally won't touch it unless I've got nothing else available. 6010/6011 (these are polarity specific) and/or 7014/7018 (DC only) are much stronger, and once you learn the fine points much nicer to use.
6013 is like playing with crayons; the others are like learning basic penmanship. (And for anyone else, stick welding is/requires penmanship). End of story.
tazmannusa
Yettem, California
Interesting statement about the 6013, if it was truly as bad as your saying they would quit manufacturing it . If you know how to weld and use proper joint prep it works fine . I have known people in the past that love it and use it on farm equipment repairs with no problems .
I have used it also, built and hung a lot of coral gates just because I ran out of 6011, no issues with strength and if I took the time to hammer off the slag it looked nicer than 6011.
I have also chewed the fat with old time welders that built ships during WW2 most of them hated 6011 and loved there 7018 and 6013
Maybe it is a personal choice?? For me, 6013 is all I have ever used, so I don't know what the others are like. I could be using the crappiest rods out there and I wouldn't know it. I weld very seldom, but I will try the 6010's next time and report back
number9
KY
I just do general welding around the property (tractor implements, jeep, etc) and like the 6011 better than 6013. Give them a try sometime.
I've got some parts on the way that will need welding on, so I'll be trying this out soon as I find some appropriate scrap to test with.
