Starting trouble 212cc predator engine.
Josh904
I have a 212cc predator motor on a go kart frame. The motor is somewhat new. Has ran fine until today. Started it up this morning fine. Then went to start it up earlier and wasnt starting. Ive cleaned carb and checked to see if gas is getting in carb, gas is getting to carb for sure. Havent pulled spark plug but ive put a screw drive in it and it is getting spark. Whenever i go to start it, it sounds like it wants to start but just doesnt. Any ideas on what i should do next?
Josh904
Nevermind lol i didnt think it would matter becausd its getting spark but will do
chancer
ɔ ɥ ɐ u ɔ ǝ ɹ
COMFORT, TEXAS
Clean the Main jet.
Just take off the carb bowl, the jet and e tube should fall out, clean them pole a twist tie wire through the hole re assemble and you should be good.
Also Do not start 2 threads on the same question. Guys will ignore both just out of Spite!
Welcome to the Forum Josh
PredatorPowaaa!!
Mistake Maker
Ontario,Canada
I've had almost the exact same problem on a 208cc honda clone where i checked literally everything, and pulled the spark plug, cleaned it, and it would never start. the most i could ever get out of it was a small puff of smoke out the muffler. one day, i bought a new spark plug, swapped it in, and it started up in 2 pulls
Poboy kartman
Senior Moments Member
White Settlement Texas
I've come across this more often than you would think. I don't know why there are so many plug failures nowadays, but, just for simplicity and insurance, if you don't have a running engine to take a plug out of , buy 2.
If neither works, call that potential problem eliminated. If both do, mark one good and keep it for future diagnostic purposes.
Rail rider
Inmate # 3192016
Planet earth ( the flat one)
Give it a shot of starting fluid ... To check if it's getting fuel if I starts and you give it a couple of shots to stay running it's a fuel problem. This will rule out if the plug is the problem.
Flyinhillbilly
The great cornholio
North West Arkansas
Not necessarily, the starting fluid is far more volatile that gas and light much easier. A plug is as cheap or cheaper than a can of starting fluid anyway.
Make sure there is enough fuel in the tank. My will not start easily once the tanks gets below about an 1/8 tank.
