spark plug = more hp
kendelrk
redneck engineer
westland michigan
so today i was looking for honda clone performance parts, and on this site there was a fancy looking spark plug that was like 10$ and it said that with it being longer that the motor gained more compression and about 3/4 hp. is this true or just a scam? :rolleyes3:
Badot
I wouldn't be surprised if it increased the power a bit.
I would be surprised, however, if it increased it enough to tell the difference without a dyno.
I imagine that plug would foul very easily as well, but someone correct me if I'm wrong. I just can't see that huge chunk of metal heating up enough to burn off any carbon.
Bluethunder3320
i believe seeing on youtube, someone got a car for almost free because they replaced the plugs with these. they fouled after like 50 miles and the guy thought no way it could be the plugs, he just replaced them. they were expensive too. i should try to find that vid.
kendelrk
redneck engineer
westland michigan
well guys after seeing how much the **** things cost ( 7.00 plus shipping ) i did a little research, from what ive heard/read ( word of mouth, unproven) it says the ngk plug would give the same performance "increase" on the motor, providing easier starting, a healthier engine, and low end would increase significantly, so on my already almost 60 dollar order from AGK i picked one up, ill let you guys know if i order any diffrence between the 2, and if theres any increase
slideways
You won't feel a difference in any spark plug change. That plug is meant as a cheater plug for the clone racing program but its technically legal. It raises compression by filling the chamber slightly when the rules are so strict. Plus the indirect spark should spread further and burn more efficiently.
Like was said.. it might show .10hp on a dyno. And its gotten so bad in racing karting that people will pay for that.
kendelrk
redneck engineer
westland michigan
eh it was time for a new plug anyways and if it does provide easier starting,some low end and it acting healthier well thats just a plus
