spark plug in exhaust
kendelrk
redneck engineer
westland michigan
drill and tap a 1 inch whole. make sure your exhaust can handle the 1.5 in in. maybe use a briggs or tecumseh flathead plug and then split the magneto wire so half goes to your main plug, and half goes to your exhaust plug
Bluethunder3320
i dont think it would do anything unless you dumped gasoline or propane into the exhaust pipe.
anything that comes out of the exhaust port is already burning
Splitting the spark will eat so much power, engine won't run. Here's how the pro's do it- Two coils. Toggle switch that selects between coils- one ground out while the other is "live". Run engine up to max RPM, throw switch. Flamethrower coil fires plug, igniting raw fuel passing thru exhaust unburnt, making flames. Before engine spins down to the point of stopping completely, switch coils again...
BTW- given the thin exhaust pipe metal, the "proper" way to do this is make or purchase a threaded bung that the spark plug fits in, and cut a hole in the pipe. Then weld the bung in.
And whoinhell says it's a 1" hole??? That's huge!
slideways
How big of a flame can you really achieve with a little 1cyl motor though. I'm curious to find out. If i was to go to the trouble of somehow making a 2nd coil mount to fire a plug it had better throw at least a 6-10" flame...
tetanus
NC
what about attaching one of those grill sparker things (no idea what theyre tech called) wouldnt affect the coil and you could constantly run it in hopes it would catch a fume coming out of the exhaust
