Some help,PLEASE
tonks79
herts uk
Hi i will keep this as short as possible,well yesterday took kart out started first time no probs but today i went out and it starts up but the wheels spin real fast i have tried the idle screw but it either runs fast or it starts to cut out there is no in between.Could someone tell me how to set the idle properly as i have looked it up and getting mixed answers.
Forgot to mention when i first started kart it started first time but soon as i turned choke off it cut out.I have a gx160 engine.Hope someone can help.Thanks.
I would also like to add that the bolt that holds my clutch on keeps loosening when started,why is that?Thanks
cumminsbayou4x4
fairhope alabama
its ether 2 problems your idles to high or your gearings way to high for it there is a screw for the idle adjustment on the carb also for your cluth bolt get some lock washers or some lock tight
It sounds like you have an underlying carb problem. Perhaps it needs a good cleaning, maybe you've got a bad intake gasket. Re: Clutch bolt- To get it decently tight, you need a way to restrain the engine from turning while you tighten it. I've had good luck using the starter handle for this. You could also take the shroud off and wrap a rope around the flywheel. There are other methods, too. Apply blue Loctite #242 thread locking compund to the bolt threads. Won't come off unless you want it to.
tonks79
herts uk
Thanks for ur replies i cleaned out carb and then reset the idle and now it works perfect again and i think i will get some of that loctite.I have some permatex red permanent strength threadlocker will that work?Cheers.
