birddog1148
I just won a small taper Salsbury Primary drive clutch on Ebay. My intention is to have it bored and broach cut for a 1 in shaft. Has anyone ever done this or heared of it?
Yea, i figured thatNope all the drivers i've seen have just been taper locked, most of the ones i've seen wouldnt really have enough meat to bore it out, but hey its worth a try. You're also going to have to change the spring and weights inside the clutch so it engages properly in the RPM range your clone has.
