Slave cylinder question
raposak
2012 Build-Off Winner
Howell, NJ
I have a pull type slave cylinder that I need to mount. the slave cylinder has the pull plunger on one side and the other side appears to be just a threaded rod. Is the threaded rod just for mounting or is there another purpose for it?
Thanks.
raposak
Howell, NJ
anderkart
Surprise Arizona USA
Kinda looks like you've got an Empi clutch slave. The threaded end is an adjustable mount.
They've got it mounted through a turnbuckle so it can pivot on this VW transaxle pic.
