All right don't exactly know if this is the right place to put this but didn't see a mower section…
So I have a Crafstman Lt1000 couple years old.
The problem is that it won't start because something in the safety wirings holding it back. So how would you basically bypass the safety wiring???
We don't have a tractor or mower section, but we do have an "Other" section. I'll move this there. Now-
Naturally, I cannot publicly condone removing safety features, so- if you get hurt, you're on your own...
Now- Start by trying to start the machine "Properly". Sit your butt on the seat (pressure switch) engage the parking brake (another switch) ensure the PTO switch or lever is disengaged (yet another switch) and the tranny is in neutral (another switch) and be sure to push the clutch pedal all the way in (ANOTHER!!!)
If it still refuses to do anything, you'll have to dig deeper. But before you do, let's continue to eliminate potential issues. Is your battery fully charged? Good electrical connections including grounds? When you turn the key to start- do you hear a "click" from the solenoid at all? Does the starter spin? What's happening?
