simple belt tensioner.
B man
Tecumseh FTW!
Oliver springs,Tn
Whats the simplest way to make a belt tensioner clutch?and can i find the parts i would need at a hardware store?
fowler
Bullsbrook West Aus
the simplest method is a type we use on grain augers of 24hp
the engine slides or pivots foward
alternatively u need two pullys and a skate board wheel
then u can put the skate wheel on an arm that pivots and there u are
B man
Tecumseh FTW!
Oliver springs,Tn
so pully on axel and pully on engine?then mount a little arm with a skate board wheel?
The Mechtician
Gargamel Jr.
Surrey, BC, Canada
That's correct, but the tensioner in your drawing is facing the wrong way. It should push the slack side of the belt toward the pulleys, increasing the arc of contact instead of decreasing it:
When it releases, it must release far enough that the belt can ride up out of the pulley and slip, but not far enough that the belt gets thrown off. This will require some trial & error in the adjustments you make. Good luck!
fowler
Bullsbrook West Aus
also the belt should be tensioned on the return side of the belt or the side that isnt transmitting the power, usually the top of the belt circle
so if the small pully in mechtician's pic was on the engine then u must turn the pic up side down
