I'm new to the kart scene and I'm just learning about the Briggs 5hp 130202 engine on the kart I was given.
After doing some reading I pulled the head off to have a look around. I noticed I can spin the intake valve when it's seated even when the engine is at TDC on the compression stroke. I can't move the exhaust valve when it's seated. It appears the intake valve is not fully seating and maybe I'm losing some compression because of this ?
I used a compression tester on the engine and I'm getting a smidge over 4lbs. Does the valve stem need to be ground or would I grind the part the valve stem rides on ? I'm not sure of the terminology of this part. The part I'm referring to sticks up thru the bottom of the valve chamber and the bottom of the valve rides on this part.
Thanks for any suggestions.
