depends on how fast you wanna go and what size sprokets and tire you have.
It seems the only way to gain a higher top speed is to use the jackshaft set up. I checked on ebay, and the smallest rear sprocket you can get is 60T. If you run a jackshaft, you'd run from the engine to the jackshaft sprocket (preferably as close to 12T as you can get.) and then from a 2nd jackshaft sprocket (18T) to the rear wheel. This would up your top speed to 36mph, and that 6hp should still have plenty of pull to get you going. Or, if possible, run a larger diameter rear wheel.
what is a jackshaft i see that word all the time on this site?
