Shifter Kart Clutch
thelordash
well i was think about build a kart with a bike engine
5 gears 125cc the thing is most ppl install a clutch handle by the steering i was wondering if i install the shifting stick next to the steering and each time you pull it backwards or forwards it acts as a clutch lever and shifts the gear at the same time so i would like to know what do you think of that
Regards
modelengineer
Lord of the noise
Sydney, Australia
It would need a complicated linkage to make sure that the clutch is depressed before it tries to change gears. What many people do is put the bike's hand clutch on the gear lever, so you just grab it and change gears. Easy to do, and it's been proven to work.
thelordash
well i agree although its a lot easier to just push or pull the shifter its way less distracting and if apply the correct throttle i think you might be able to shift with the clutch at all
modelengineer
Lord of the noise
Sydney, Australia
You can definitely do clutchless shifting. Whether it's good for the transmission I don't know, all I know is that I don't do it because it just seems like a bad idea.
It's easy to put the clutch lever on the gear shift lever, so why not try that first and if you don't like it then you can try something else?
fowler
Bullsbrook West Aus
more appropriate is a system that u twist the handle to activate the clutch (pic 1 looking top down)
or a system that u push the lever away to activate clutch
not fully semi auto but easier than a hand lever from the bike
redsox985
PA
I say on one kart where a guy loosened and rotated the foot shifter to vertical and extended the shifter with pipe the same OD as the twist throttle. He slipped the twist throttle onto the shifter arm and offset the motor to the right of the driver. He zipped around with his right hand on the throttle/shifter arm and left hand on the wheel. It was "sdraw ssa kcab" but pretty cool. Then he ran the clutch to a foot pedal. Home brew but effective.
