JonathanEngr
I recently purchased a "buggy" cart that has a 196cc Homelite engine. Some folks in this forum (in another post) told me it is a Honda GX200 clone, and the info on the engine is as follows:
CHONGQING HENSIM GROUP, 6CHGS.1961CH, HOMELITE 196CC, OHV
I know very little about small engines (or large engines for that matter) but can someone explain to me how to find/set the idle on this engine? Once cranked, it wants to begin rolling immediately.
I have followed the throttle cable back to the throttle assembly, and I see the spring going to the gas tank that, I assume, allows more gasoline to flow when the pedal is depressed. I've made 100% sure this spring is completely slack, and it still idles too high. There's an adjustment screw on the throttle assembly, but it only limits the range of the throttle assembly. There's also an adjustment screw on the carb, but I assume that's to adjust the air mixture....?? For the life of my I can figure out a way to throttle this thing down. Other than this, the kart runs great!
