robbie
Remember the thread about weed whackers, where somebody mentioned a 4 stroke engine that runs on 2 stroke mix? I've been wondering if you could do the same thing with a vertical shaft Briggs 8 hp to mount it with the shaft horizontal. If you could mount the carb on the side of the case, then run a pipe from the other side of the case to the intake, and plug the breather, maybe it would lubricate the crank adequately. It's not like a car engine with oil pumped into the bearings. It's splash lubed under normal conditions, so maybe this would work.
I don't remember how the breather looks on these engines. I have one sitting outside so I ought to look at it. But I wonder if you could mount the carb there instead of the cover plate, to lube the valve gears directly.
I know it sounds like a crazy idea, but if you want to run a vertical engine horizontal you have to rework the carburetor mounting anyway....... but now that I'm thinking of it, it's probably a lot easier to just make an oil slinger and an intake adapter.
