JonathanEngr
Well, now that I have my kart (sorry--the kid's kart!) running in tip-top shape, I'm moving into the aesthetics. One of the first things is the key switch.
I purchased a Carroll Stream 6.5 HP engine (you can see it on carrollstream.com, on the left bar mouse over "gas engines" and then choose "electric start") that came with electric start and a key switch assembly mounted on the engine. I extended the wires and ran them to the front of the kart, and mounted the switch beside the steering wheel. However, as you can see from the pic the switch is large and cumbersome.
I assumed swapping it out for another switch would be simple, and perhaps if I was a bit more electronically inclined it would be. But... I'm not. After searching for a bit, I've found "go kart" switches with 2, 3, 4, 5 and even 6 leads. Does anyone have any idea what exactly I need?
I did disassemble the key switch housing when redoing the wires, and check out the switches operation with my tester. Basically, I tested resistance to see what switches are closed in the three switch settings (off, run and start). On the back of the switch there are 5 wires soldered to the switch. Two wires are white, and they are soldered to the same lead. Thus, we'll call that a single wire. Then there is a black/red wire, and two black wires (so is it a 4-wire switch??). I'm fairly certain the white wires are responsible for engaging the starter, so we'll put those to the side. With the key in the "off" position, the black/red wire showed no resistance with the two black wires, so they are all connected. In the run and start position, the black/red wire is connected with only ONE of the black wires. I'll be happy to sketch something up if it is helpful.
I do have a scan from the manual that shows thew wiring diagram I'll place here, too. Hopefully someone can make a recommendation!
