Removing reduction gear
Revhead
Alberta, Canada
Newbie here, I just purchased 3 used go karts all with gx160, one of the motors is seized and I have a spare motor
Wondering how to remove the reduction gear case from the seized motor?
Thanks in advance for any help
Keith
Nodroz
Belgium (Europe)
Drain oil, and open up the side cover of the reduction case.
Once open, you need to see if you can attach the bolts without removing the clutch. There should be 4 bolts attaching the reduction case to the engine.
Goodluck!
OK, here goes. I made this for someone I sold the gear reduction unit to, so you will have to work backwards. I was explaining to him how to install it, not remove it
Pic 1 – What the engine plate looks like before the clutch is installed
Pic 2 - Put the gasket on
Pic 3 – Slide inner case on and tighten bolts in this order. Top right. Bottom left. Top left, bottom right
Pic 4/5 – Slide spacer onto engine PTO
Pic 6/7 - Put keystock into keyway
Pic 8 - Take internal clutch, chain and outpu shaft, and put it in the inner casing, sliding the engine PTO into the clutch drum, lining the key up with the keyway in the clutch drum
Pic 9 – Put spacer on the clutch drum, making sure that it lines up with the key so that it fits correctly.
Pic 10/11 – Put bolt in the clutch drum. This will thread into your engines output shaft. If your output shaft is not threaded, you will have to get it drilled and tapped.
Pic 12 – Put outside cover on and tightens bolts. You need a size 8 spanner.
It is easier to do the install with the dipstick out. When installed, you can use normal engine oil to fill case to the required level
