Silly question, and first post (cough, cough)
I had just recently acquired a 5hp b&s motor, sort of similar to yours above Magice... but, here is the thing, I would like to actually remove the governor from the block itself, it is a mechanical governer that has the lever on the outside of the block, attached to the gas tank frame mount.
I plan and was planning on going with the straight throttle linkage to the carb, and bypassing the governor itself, but how would I go about actually removing the governor from inside of the engine itself?? Looking at the IPL of my b&s model engine, it looks like there will be a small opening on the side of the block where that Governor arm was previously located, after I remove it. Any input guys??
Thanks again!!!! ps, I've done tons of reading from you guys so far.. and I'm definitely impressed! I've learned alot in one day!! brings back the memories from when I was younger and working on karts!! lol
Thanks!
-Tylor
