Reconditioning Briggs & Stratton 8HP Engine
fresh101
Pembroke Pines, FL
Hello Everyone, I am requesting some help from this community for my upcoming project. I was given a B&S 8HP engine which has been outside for 2 years with no use. It's missing a carb, gas tank and some wires that are not connected, coming from the on and off switch going to the throttle portion. The engine looks pretty bad, some rust spots and it's really dirty. I have lots of the outer portion parts off for sand blasting and if you guys can help me, I will be finishing opening it up to deep clean the parts inside (valves, piston, rod, crank, cam, lifters, head). I would love to recondition the entire engine but only if I can find the following parts: gaskets, carb, filter, magneto coil, and assembly instruction or diagram of the throttle portion for this engine. The engine is a model: 196432 type: 1215 E1 code: 990225yd (date: 02-25-99). If I can't get replacement parts, I will not even bother opening it up.
Thanks in advance for the help...
fresh101
Pembroke Pines, FL
Being a B&S, parts shouldn't be too hard to find & I'm sure we can sort you out with the carby & wiring without a problem. Where are you located?
Landuse is currently doing a rebuild, have a look at the thread:
http://www.diygokarts.com/vb/showthread.php?t=16886
There's a lot of advice & tips in there if you need help along the way
I am located in Miami FL
I have seen it and have been following on his breakdown but it's a Yamaha and it is said similar to a clone 5.5 or gx160. I am after the parts for B&S model: 196432 type: 1215 E1 to restore to like new condition. I need the gaskets mainly if I am going to open it up completely and will also need the diagram on the magneto connecting to throttle portion. Thanks for you time and help
I realise that, I thought, as all engines are pretty much the same, you'd be able to use his thread as reference.
As far as parts go, I can't help you with that but, I understand parts for these engines are easily obtainable in "the states"
