Rc set ups?
youngengineer
Cumbria, UK
Don't know if anyone can help but me and a friend are going to attempt a decent sized rc car, 3ft long maybe? We are thinking of making it from wood proberly, I know how to do the mechanical side of things but I don't have a clue with servo, receiver, transmitter, speed controller type of thing (never worked with it) its preferably electric but if petrol is easier I can get a small petrol engine. Any help much appreciated!!
firemanjim
Just kartin' around....
Houston Texas
:popcorn:
I'm gonna go out on a limb here cause I'm bored and waiting for answers myself.....
Ok, back in high school, I was big in to RC. Had bunch of radio,and remote controlled toys. I had this HUGE remote controlled truck, but walking behind it everywhere sucked. So I had the same idea as you have now. I decided I was gonna make my own gas powered rc car out of this truck, a broken Tamaya Grasshopper,and some small diameter copper tubing. I drew out my frame design, then started to cut tubes to make the frame. My dad showed me how to solder copper, and I got to work... I made a frame like a sand rail, tube chassis,big enough for the truck body to fit. My dad put some small plates where stuff would get screwed to, I think he riveted them. We mounted a small weed eater engine. Then I used parts from the grasshopper to make the rear drive and the wheels and tires. My dad got me a long skinny bolt to use as axle. I used a gear from the gearbox as the axle sprocket and my dad put one on the engine (I don't remember how) . We used a big thick rubber band, from his work , as the "chain". This all worked great as well as the swingarm. I failed big time on the front steering, so fast straight lines where never possible. But at slow to medium speed, it would handle decent and really sling some mud...
The thing I built was light enough that the front steering components and steering servo was good enough for the job. The bigger/heavier it is, the bigger steering servo you will need. The throttle can be done with a cheap walmart rc toy servo. But, if you want brakes, get a good one. You can pull for throttle, and push for brake,on a pistol grip controller. That's fairly simple to set up..
I done lost track....... Exactly WHAT do you wanna know? I'm no expert, but I do know a little..... :popcorn:
youngengineer
Cumbria, UK
Thank you soo much, that helps quite abit! Yes I was going to put brakes and throttle on same servo like u said then I can use a normal 2ch remote! Do u mind if I personal message u for help if I need it as u seem to know quite alot!
firemanjim
Houston Texas
LOL... Me know something? :lolgoku:
It's actually better to leave it all here, cause someone else might want to do the same or similar. There are others on here that know a lot more about the subject, but I'll help ya where I can, maybe it will coax a real expert to chime in and correct me when I'm wrong.....
You got to start with a plan first. What parts are you going to use and where do the come from. What the chassis gonna be made from and how. Whatvengine,and how to mount it. If you don't have a good plan in the beginning, you won't have a good end product....... :thumbsup:
Do some home work. See what it's gonna cost you for all the things you need. Is it really something that you are going to be able to do, afford to do, and actually finish it,so you're not just wasting time, money,and breath..... (talking about it)
youngengineer
Cumbria, UK
Haha thanks! That's a fair point, other people may need the same help! I intend to use wood, I have some 60mm X 30mm pine (I think) which is strong enough to hold my weight. I'm using this rc setup... *pic* and these build components...*pic*
The plywood is 6mm
I will proberly draw some plans tonight and make a basic frame tomorrow, what would u say is a good size to make it?
ML-TOYS
long island, new york
What scale is that servo. With rubber tires like those you will need at least a 1/4 scale servo. Unless you want to drop some $ on a linear actuator
youngengineer
Cumbria, UK
Its a 10kg servo, I may wait abit longer and make the frame from metal as it will be more durable and better, what do u think? I can't weld at the moment because I broke my wrist and collar bone about 4-5 weeks ago but will be able to as soon as I get my cast off
