scrotty
I'm looking to mod a Razor Ground Force for use by my 8 and 11 year old kids.
My reason for modding is two-fold: 1) Increase runtime, 2) Slightly increase performance.
Based on what I've learned from itsid's excellent sticky post, I've made the following observations:
1) The total weight of kart (plus batteries mentioned below) and kid is ~125kg.
2) I'm plenty happy with max operating inclination of < 10%
3) I'd like 1.5 hours of run time per charge
4) The Razor GF has 4.5" wheel diameter
5) I want to limit top speed to 7.5 m/s (~26 km/h or 16 mi/h)
And from this and itsid's formulae my guesstimates:
1) I should be looking for a 24v/500W motor* (the stock model for this model is 24v/250W)
2) I'll need four 12v/18ah batteries in which pairs are to be wired in parallel and those pairs then serially for a 24v/36ah total. (These batteries are ~6 kg each, adding 24 kg to the stock kart minus an estimated 5 kg for the stock batteries which I'll remove.)
My two questions:
1) Does this seem reasonable?
2) How do I cap top speed? Can this be done with a controller? I take it I need some way to limit motor rpms.
TIA!
Sean
* I show how I arrived at this guesstimate a couple posts lower
My two questions:
TIA!
Sean
