When it comes to ATV use (yes I'm counting off road go karts in that group), there are a lot of grey areas when it comes to access. But those grey areas turn black real fast when your kart is screaming like a chainsaw. I want my kart to be more.... discrete. My options for riding will open up a lot if I can ride without attracting all sorts of attention.
So I was thinking about it one day and I had a possibly great idea... What if I slapped a golf kart muffler on my engine! It's a 6.5 HP subaru robin. And I know that 'slap on' means bolt on the muffler and then fabricate some kind of support structure for it, so at least a little bit of welding. And maybe some pipe work. It would probably eat up a little bit of power, but if my kart was silent, that would be very good.
Or, are there other ways to quiet down one of these engines?
Unfortunately, the
laws of sound travel, hinder to making an 'open aired' engine silent... metal on metal, hitting/sliding, little explosions, air compressioning all cause 'noise'. So 'even' if the exhaust 'noise' is all but removed, there will be other things that will cause a racket, especially at higher RPM's... but this isnt exactly what you want to hear... so...
IMO, suppressing a 6.5/5.5 engine's exhaust to being 'silent' is possible/plausible, however at a cost to either power or space. On a norm, for clone engines, the level at which 5-6.5hp is initiated, is at a higher rpm. 'If' some of the torque/pressure is removed, to silent the expulsion of exhaust, then said 5-6.5 engine becomes something closer to a 4-5hp. So the question is how to remove sound w/ as lil loss of hp?... and the only other course of action is imitate an automobile stock exhaust system... FYI, Im NO
pro at exhausts,
however Ive dabbled w/ em, and as far as sound... Im better than avg. My reasoning is cause I design/make custom speaker boxes...
A. Stock exhaust manifolds are restrictive to air flow, which equates to restricted 'sound' travel. So leaving the stock outlet of combustion at a smaller diameter,
helps.
B. A CAT/catalytic converter is the
next restrictive mass, that will also restrict/scatter sound travel.
C. Next, a resonator (smaller diameter ricer exhaust, w/ a smaller outlet vs. the trumpeted) is inline to scatter the sound even further.
D. After a length of bends and straights, the sound is 'deepened' in octave, and the muffler is next to the last restrictive item. Sound is scattered through out a series of chambers, which lessen decibel levels by deepening/restricting them to said chambers as it travels through them.
E.
Lastly, in 'some' cases, a 'tip' is implemented to change the final 'tone' of the exhaust. A smaller diameter will cause a lesser higher pitched tone, where as a larger will create a muffled lower tone.
Im
not saying that '
ALL' this is
needed to silence exhaust...
some is for emissions. And Im
not saying that by fabricating a similar setup
will silence it...
even though Im sure it would. What I
am saying is that most all the rules (earthly laws) of karts, are a
give n take, scenario (aswell as 90% of 'life')... so... I still aint
really answered your question...
This is just a 'bug in your ear' kinda thought for you to toss around... instead of trying to muffle the exhaust... how bout focusing on the 'noise', seeing as that is the 'issue'.
A mental image of... an elbow pipe extending off the existing muffler, traveling down to a 'box' (the bigger the better) lined w/ a heat resistant material that scatters sound... like steel-wool. And have the outlet of sound being projected to the front of the kart, under the seat. Spraying a thick layer of rubberized undercoating the frame/seat would
help slightly, aswell as help w/ minor vibrations.
ALL this is just a fabricators thoughts gone adrift. I by no means
condone doing ANY of what I suggested. Id personally just deal w/ the exhaust... or go electric!
