Quick advice
Correct me if I'm wrong but this is a great deal right?
http://tampa.craigslist.org/hil/mcy/4199020385.html
Please tell me it's possible to put slight larger off-road tires on it to at least five in the grass for my daughter
It looks like a good deal, and you could put slightly larger tyres on it. Emphasis on slightly. You might need to change the gear ratio if the tyres cause a acceleration problem.
That kart is also quite small, so just make sure that your daughter can fit in it. Also make sure that it is just the battery that is the problem, and not some other electrical problem
dcastillo
Tampa Florida, USA
She will easily fit, she's only 4 :)
Thanx for the reply...
I was planning on covering a had one to electric, but this seems like a great deal... The controller and motor are easily with more then 125....
Oxymoron
Newbesque builder.
Maryland
That thing is sweet. I didn't know those little Honda's even existed. Very cool :thumbsup:
dcastillo
Tampa Florida, USA
score... looks like I found an offroad tires that works just fine...
put it on the cart and have about 1/4" clearance to the plastics :)
also got the paint job done
question, does anyone know where I can find a smaller #25 sprocket for this thing to compensate for the tires?
its a double D 11 tooth on an My1020 motor... cant seem to find anything smaller... a 9 tooth would be perfect
thanx
Danny
dcastillo
Tampa Florida, USA
This thing is a beast with bigger tires...
https://plus.google.com/110092450585525099652/posts/ggKYGWj6DxQ
Now does about 15mph which is pretty scary for a 6ft guy in that thing....
One issue I need to fix is the steering setup.... its like a real race car...
The steering wheel only turns 30deg at the most... makes high speed turning dangerous....
Need to get it more like a normal mart... a good 60deg or so in each direction would be good...
Stay tuned for more ;)
Oxymoron
Newbesque builder.
Maryland
You could shorten up the pitman arm and lengthen the steering arms, but in that pic, the pitman doesn't even look that long as it is... you could probably still go a little shorter though.
Half-breeder
"Edit" button removed
Yea it is! Somethings missing though... ahh... a tow hitch!:thumbsup::lolgoku:
Like Oxy said would work... and that steering arm 'does' look awfully short to me aswell. Try 'just' lengthening the arms at the wheels(maybe1/2-3/4 inch), and 'ensure' that they point to the same center point on your axle(center of rear axle). Thatll ensure proper Ackermann as you 'finagle' around w/ the steering.
dcastillo
Tampa Florida, USA
Thanx for the advice, those mods will have to wait till after Christmas though :)...
Here she is, looking mighty pretty
