Question on lawn mower engines
dictionary6767
Nj
Okay so i bought two walk behind lawnmowers at a auction (a scag and a bobcat). Neither run and they are in poor shape, but they were only 25 a piece so even if they both need new motors its a good deal. I took the pull stater off the scag since it was broken and i can turn the flywheel either way a half way and then it wont turn anymore? Does that mean there is something internally wrong? I am going to take the head of this afternoon and see how it looks. The bobcat appears to be in nicer shape by the way it looks, but havent checked if the motors is free yet. What would be a good replacement motor? They both have motors on them now that produce about 15hp.
justinlogue5_0
Can't leave it Stock!
Tn
Either internals are messed up or there is something attached to the crank that is in a bind (pulley, clutch, engaged starter etc...). Pics of it would help us as well.
Poboy kartman
Senior Moments Member
White Settlement Texas
They have to run to produce 15 hp.:lolgoku:
Yeah....sounds like the first one might be internally damaged....but pull the spark plug wire and try turning them by the blade....and look for any exterior obstructions first.....
If you pull the head....you will need a new gasket that you might not have otherwise needed....
