quad is smokey when cold???????
zip kart
ireland
ok so i have a 110cc loncin quad
my problem is when i start it up its smokey when i use choke but when i turn off choke and it gets warmed up its ok ???
also i had a intake leak a while back and i replaced the o-ring and spacer and i also taped around the outside of the intake mani using
masking tape and electrical tape to prevent further leaks
checked spark plug and it was grey with oil arounf the edges?
fowler
Bullsbrook West Aus
Elec tape won't prevent intake leaks
That's pretty redneck:lolgoku:
The reason it smokes a bit with the choke is because the choke is "choking the air"
It gives the engine a really rich mixture which is alot easier to burn
The smoke u are seeing is the same as if u had a dirty air filter or if the needle or seat was to fail
Another thing to remember is an engine has super tight and precise clearances
These are set so it performs well when it's warmed up
When cold an engines clearances are all off
So sometimes some oil can leak though and be burned
Just look at alot of older cars on a cold winter morning
zip kart
ireland
i used masking tape aswell lol over the electrical tape
another thing is i was driving it today and it was spulttering it didnt have full power
would this be a carb problem or air leak?
devino246
Official DIYGK Chem Nerd
Lynchburg, VA
You used tape to "seal" the intake. What do you think?
zip kart
ireland
ino ye not such a good idea
went for a drive and it was spulttering if i go easy with throttle and if i go harder its ok , doesnt seem to have full power ?
zip kart
ireland
alread did just for some reason i taped around the intake to make sure it wouldnt leak again ,
im cleaning out the carb right now found that the new o-ring that goes between the spacer ,was wore abit
only got this a few weeks ago
i have a box of o-rings but the onlt one i can use sticks our abit ,its abit ticker but fits?
zip kart
ireland
cleaned out carb truly again was really clean maybe a few bits noting major
cleaned spark plug
checked gap 0.8mm
checked throttle cable setting and the stem was 2 from the top so it was on the leaner side so i put the clip in the middle
went for a drive and it still had no power ,spluttering but if i use throttle wide open it seems ok but still splutters
and when i drove back into the shed and let it idle it was poping ,back firing abit
and a weird noise seems like an electical noise spitting noise dont no where its coming from
doesnt happen that much but i dont no after that ?
an help would be great
Sorry, man. I just can't make sense of your description. Stuff like "If I use throttle wide open it seems ok but still splutters". Wut? Either it's okay, or it's not. No?
peterbilt
Denver,Co.
If you can't duct it, **** it. Good ol duct tape won't work on any engine. But props for tryin and giving all of us a nice lil laugh :stir:
I would like to see pics of this "tape mod".
jamyers
Buffalo Gap, TX
Well, in his defense... I've got electricians tape wrapped around the cheap rubber hose from the air cleaner to the carb on my Chinese atv engine. Works soo far... 😄
I saw an episode of mythbusters where they made a cannon out of duct tape, and it worked nearly as well as a normal cannon. They also made a sailing boat and held a car up in the air suspended with the tape.
That is some strong stuff!!
jamyers
Buffalo Gap, TX
My nephew turned me on to Gorilla Tape - it's the steroid-laced, musclebound, cigar-smoking, just-outa-jail big brother that makes duck tape seem like post it notes, LOL
I have seen that stuff at Home Depot. I thought it was just overpriced duct tape. Guess not, eh?
If they made duct tape with Tuck tape (red sheathing tape) adhesive, the stuff would be incredible!
