Proper spark plug and gap for HF 6.5 hp blue engine
ghostdog
Does anyone have their manual for the blue greyhound harbor freight 6.5 hp engine?
I am looking for the spark plug and gap to use.
I tried looking at the real Honda GX200 and it shows a gap between 0.70 0.80 mm(0.028 0.031 in) and to use plugs BPR6ES (NGK) or W20EPR-U (DENSO).
Is that what we should use on the gx200 clone?
Bluethunder3320
yeah i did mine to gx200 specs and seems right since the engine is almost an exact copy
EDIT: i havent read the manual but there might be something in there.
Badot
Well... I'd say when in doubt, go with the manual. If the chinese company took the time to not copy it straight from the honda manual, there's probably some reason they did.
I don't know my spark plugs, but I would have to assume they would have to be similar to run properly. Either way - if you had one before and it ran satisfactorily, that's reason enough to keep the same type.
