Problems with brand new engine or my own doing?
Sourdiesel408
I just bought a 208cc ironton go kart about 3 4 days ago. I changed the oil twice now both times smelt kind of like gas and metal shavings. I didn't think any about it cause runs great. So today I changed again for heck of it. Put royal purple this time and it smelt like gas again, also metal shavings just tiny little specs that you can see floating around.
At this point I'm worried about my engine it's not knocking or anything. just gas getting in my oil and causing metal shavings possibly but this is a new motor so I know that it's normal for some metal. I have inspected piston took off the head and no carbon brand new. What could be causing the gas in oil?
If the carb petcock is left open, the gas typically leaks back into the crankcase. For what ever reason, they all(the clones and the honda brand) do.
I have had this happen to me several times....
Both times the motor ran great....
Was the motor "broke-in" properly with regular dino oil?
Sourdiesel408
Idk to tell you the truth...... I bought it from a kid who sells them he said he don't really ride it. So if I turn off my fuel shut off valve I should be fine? It's right on the carb I believe an I do have a habit of leaving it open.
---------- Post added at 01:18 AM ---------- Previous post was at 01:15 AM ----------
And yes motor runs great, it is also brand new though
---------- Post added at 01:36 AM ---------- Previous post was at 01:18 AM ----------
The only noise I hear from my engine is chatter from the clutch.
Sourdiesel408
If I keep the fuel shut off valve off while not riding then no gas will get into my oil correct?
