Predator throttle hook up
Imthegrt1
Ironman returns
Kentucky
Got to love the 2nd version of these motors.from when the first came out.
I mean so simple to install throttle cable .
I dont know why so many try to custom the linkage all you have to do is loosen top bolt some.
And back out throttle screw .
Clamp down cable and your done.
You don't even have to add a spring.
Depending on how long the throttle cable is.. then you may want to have an additional return spring....
Imthegrt1
Ironman returns
Kentucky
Correct.but for the doodle bugs they work perfect even better setup than the factory motors
chancer
ɔ ɥ ɐ u ɔ ǝ ɹ
COMFORT, TEXAS
Dude, Add a spring.
It is only the Governor springs that are returning you to idle.
or
Make darn sure you really really trust your kill switch and NEVER let anyone besides you ride it.
It is just good safety. and as easy to install as the throttle is.
Mine below is with the Gov removed but check out the little spring I added. I even used the stock parts. I just got lucky and had that spring.
Dude, Add a spring.
or
There is a little return spring built into the stock throttle plate???
Even ebay knows that. (and every pic above)
http://www.ebay.com/gds/Predator-212cc-Throttle-Linkage-Kit-Instructions-/10000000205740295/g.html
But I'd add another.
---------- Post added at 02:49 PM ---------- Previous post was at 02:40 PM ----------
I just clamped the housing on Mt Bike brake cable and tightened the end of the cable like the Great One did, but I also added a 2nd Return Spring to make sure the Throttle snapped back (100% closed at the Butterfly) when I left off the pedal.
Imthegrt1
Ironman returns
Kentucky
Which is a good idea idea I've just always ran them like this .but I did pick up a pack of springs today.
That's why this site always great always good enough even when not thinking about it .
chancer
ɔ ɥ ɐ u ɔ ǝ ɹ
COMFORT, TEXAS
I just would not trust that little guy. Plus 3 out of 4 of my Karts are for my kids.
Glad OP decided on an additional spring.
chancer
ɔ ɥ ɐ u ɔ ǝ ɹ
COMFORT, TEXAS
Me too. and on my kids karts I actually welded a nut to the back of the seat for a place to hook the spring from the lever.:thumbsup:
